No se puede,cableado diferente,centralita,botones de control etc.Medía moto habría que cambiar.Es mejor ir a por un display aftermarket tipo a este https://i2m.it/en/products/chrome-lite/
Que es la caña también y está pensado para la 2016 .Viene super completo,lap timer y velocidad por gps..etc..etc...
- 800x480 Graphic Color Display
- High visibility even in direct sunlight
- 1 GHz Processor, 1G memory
- Aluminum case
- Fully customizable in two configuration PADDOCK/TRACK
- 10Hz Trajectory and GPS speed acquisition, 66 parallel channels
- Lap timer whith 20 pre-loaded tracks, 500 laps per track
- Track Auto identification, 3 splits
- Best Lap, Ideal Lap, Best historical and daily values
- User friendly interface
- 12 high brightness alarm leds, fully customizable
- 8 10 bits analog inputs
- 2 distinct sped inputs
- 1 RPM input
- Water, fuel, oil inputs with dedicated alarms
- Gear in use with auto learning
- Data download via USB key
- 2 buttons remote command available
- CAN BUS ready
- 1GB internal memory
- 3 different distance meters, up to 2 hours, total laps
- Auto generated stoichiometric ratios table (optional probe)
