En el manual te lo pone, pero es fácil, si no recuerdo mal:
Contacto a la moto, se elevará la saeta hasta donde lo tengas puesto (por defecto los 6000 que dices).
Cuando baje a 0, pulsas C, manteniéndola 3 seg y la saeta subirá hasta donde quieras. Entonces sueltas y ya tienes puesto el avisador de max. regimen.
No obstante te lo busco y te aseguro de ello.
Q: How do I set the redline threshold light?
A: With the key on, but engine off, use the
C button to set the counter. If the C button is pressed momentarily
for less than one second, the pointer will remind you of the current
setting. To set the redline, push C, release it, then within three
seconds press C a second time. As long as you hold in the C button,
it will step up by itself (and wrap around if you go too high).
To step it up slowly, release and click the C button momentarily
and the needle will go up by 100 rpm each click. If you wait three
seconds, without doing anything, you may be forced to start over.
When you are done, press and hold C again for three seconds to store
the setting. Confusing, but you get the feel for it. Keep in mind that
this is just a reminder light, and doesn't change the rev-limiter.
Esta página aunque es de Falco te puede servir en mucho a tu Tuono:
http://www.oocities.org/sl_mille/index.html
