Me preguntaba si alguien ha probado estos reglajes....que os parecen???
  los he sacado de:  http://home.comcast.net/~sl_mille/suspension.html
   Fork
            Setup  |
      | Description |
        Stock Showas 43 mm USDs with steel cartridge |
      | Installed height |
        4 spaces showing (16 mm triple to anodized cap) |
        3 spaces (12 mm) |
      | Valving |
        Stock |
      | Rebound screw setting |
        0.75 turns out |
        1.5 turns out |
      | Compression screw setting |
        1.75 turns out |
        1.5 turns out |
      | Oil viscosity |
        5W (Showa/Honda Pro) |
        probably 5W or 7 .5W ? |
      | Oil level |
        150 mm (from top, collapsed, no spring) |
        116-120 mm |
      | Spring rate |
        0.95 kg/mm |
        1.01 kg/mm |
      Spring free   length |
        272 mm |
        292 mm |
      | Preload spacer |
        128 mm plus stock washers |
        100 mm |
      | Preload cap |
        6  lines (12 mm from anodized to taper) |
        5 lines (10 mm) |
      | Sag (bike) |
        22 mm |
      | Sag (rider) |
        35 mm |
        25 mm |
      | Shock
            Setup |
      | Description |
        Penske 8981 (8900 series deCarbon damper
          with 8100 reservoir) |
        Sachs emulsion-type damper |
      | Installed height |
        ~320 mm eye-to-eye ~ 1 thread showing
          on adjuster |
        ~312 mm non-adjustable |
      | Sag (bike) |
        ~5 mm |
      | Sag (rider) |
        32 mm |
        41 mm |
      | Spring rate |
        800 lb/in (6-inch spring) |
      | Oil viscosity |
        standard |
      | Valving |
        standard (track) |
        ? about midscale +2 to +4 more clicks |
        -16 clicks from full-in |
      | Compression knob setting |
        "1" of 6  (largest orifice) |
        non-adjustable |
      | Preload |
        20 mm threads above lock ring |
        41 mm threads above lock ring |
Motos:
Rsv 99: Bestial
rsv 2002: PERFECTA
