Me preguntaba si alguien ha probado estos reglajes....que os parecen???
los he sacado de: http://home.comcast.net/~sl_mille/suspension.html
Fork
Setup |
Description |
Stock Showas 43 mm USDs with steel cartridge |
Installed height |
4 spaces showing (16 mm triple to anodized cap) |
3 spaces (12 mm) |
Valving |
Stock |
Rebound screw setting |
0.75 turns out |
1.5 turns out |
Compression screw setting |
1.75 turns out |
1.5 turns out |
Oil viscosity |
5W (Showa/Honda Pro) |
probably 5W or 7.5W ? |
Oil level |
150 mm (from top, collapsed, no spring) |
116-120 mm |
Spring rate |
0.95 kg/mm |
1.01 kg/mm |
Spring free length |
272 mm |
292 mm |
Preload spacer |
128 mm plus stock washers |
100 mm |
Preload cap |
6 lines (12 mm from anodized to taper) |
5 lines (10 mm) |
Sag (bike) |
22 mm |
Sag (rider) |
35 mm |
25 mm |
Shock
Setup |
Description |
Penske 8981 (8900 series deCarbon damper
with 8100 reservoir) |
Sachs emulsion-type damper |
Installed height |
~320 mm eye-to-eye ~ 1 thread showing
on adjuster |
~312 mm non-adjustable |
Sag (bike) |
~5 mm |
Sag (rider) |
32 mm |
41 mm |
Spring rate |
800 lb/in (6-inch spring) |
Oil viscosity |
standard |
Valving |
standard (track) |
? about midscale +2 to +4 more clicks |
-16 clicks from full-in |
Compression knob setting |
"1" of 6 (largest orifice) |
non-adjustable |
Preload |
20 mm threads above lock ring |
41 mm threads above lock ring |
Motos:
Rsv 99: Bestial
rsv 2002: PERFECTA
