Interesante página de la EPROM de Aprilia.
http://www.randomexploits.com/projects/ecu/home_ecu.htm
Aprilia EPROM History
This is an incomplete history of the various EPROMs that Aprilia shipped with their Gen1 ECU (Mille, Tuono, and Falco).
The first set of EPROMs share a common codebase. This same basic codebase was shipped with all the small-valve engines.
| EPROM ID | Model/Year | Derestrictable | Trim Pots Work | EPROM Checksum | Notes |
| Sport854 | RSV/1999 | No | Yes | 92D9 | - The very first RSV EPROM.
- This EPROM was for the original 'small' 36mm intake valve cylinder heads.
- Only contains a derestricted map.
| A63 | RSV / to 2000 | Yes | No | 7868 | - Based on a modified Sport854 EPROM:
- Added a restricted map
- Derestricted map was made a bit leaner
- Trim pots were deactivated
| P08 | Falco/00-02 | Yes | No | 5F76 | - For small intake valve engines (36mm)
Starting
in 2001, the RSV engine got larger 38mm intake valves, up 2mm from the
original 36mm intake valves. At the same time, the ECU firmware got
changed to a slightly different version. All RSV ECU EPROMs from this
point on use the new codebase.
| RP58 | RSV/01-03 | Yes | Yes | AF2A | - Europe still got the RP58 in derestrictable form in 2001-2003.
- USA got the RP58 for 2001 only.
| RP58USA | RSV/2002 | No | No | | USA only: - Same codebase as RP58.
- The derestricted data maps are identical to restricted maps, so cutting the derestriction wire does nothing.
| 549USA | RSV/03 Tuono/03-05 | No | No | | USA only: - Mufflers have catalytic converters.
- Same codebase as RP58, but different data maps.
- The derestricted data maps are identical to the restricted maps, so cutting the derestriction wire does nothing.
| 549EuroC | Tuono/03 | Yes | Yes | 86DE | Europe only: - Tuono without catalytic converter (shiny muffler)
| 549EuroKatD | Tuono/04-05 | Yes | Yes | 90EA | Europe only:- Tuono with catalytic converter (black muffler)
Tuntuneando mi Falco
http://v60.es/forums/thread/40771.aspxModelos RSV
http://v60.es/forums/thread/60585.aspx
